Aller au contenu principal
The LG 60LM6450 is a 60-inch LED television released in 2012. It supports 3D video with glasses at a resolution of 1920x1080 pixels.
76 questions Voir tout
cleaning of my tv
hey got a quick ???? my wife but a new micro fiber cloth to clean tv now there is smears all over it .....also since she used it it looks like back light bleeding..... on some areas could that just be the smudge marks cuz thats where they are …
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
jose rozy post some pictures of what your screen shows This "also since she used it it looks like back light bleeding" makes me a bit suspicious that there maybe more going on. Ajout d'images à une question existante
par
Ajouter un commentaire
1 Réponse
Solution retenue
Here's how to clean a flat screen TV:
  1. Turn off the monitor. If the screen is dark it will be easier to see the dirty and oily areas.
  2. Use a dry, soft cloth -- the kind you would use to clean your eyeglasses -- and very gently wipe the screen. If this doesn't remove the oil or dirt, do not press down harder and try to remove the dirt. Pressing down on the screen will cause the pixels to burn out. Rather, proceed to the next step.
  3. Make a solution of equal parts water and vinegar (or water with a tiny amount of dish soap). Dampen a cloth in the solution and gently wipe the screen. Again, rubbing and scrubbing will damage the screen.
Here are some important tips you should know:
  • Avoid using paper towels, toilet paper or something like your shirt to wipe the screen, as these may scratch or damage the screen.
  • Do not use products that contain ammonia, ethyl alcohol, acetone or ethyl chloride. These chemicals, which are often found in commercial window cleaners, can cause the screen to turn yellow.
  • Never spray liquid directly on the screen as it can run inside the monitor and cause damage
Indice 1
Ajouter une réponse
jose rozy sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 91
