GE Profile occasionally will not pump out
Dishwasher won’t pump out..hose clear…remove standing water manually.. try running again and it works perfectly…3 washings later it does it again….
Tutoriels de réparation et de démontage pour les lave-vaisselle.
Rep: 11
There is not anything wrong with it. Check the float at the bottom of your dishwasher and make sure it is clear, if it is your dishwasher probably just needs a hard reset. Turn the breaker off for 4-5 minutes, after you turn it back on hold the cancel button down for 3-5 seconds. it will go through a drain cycle and then your dishwasher should be fine.
Commentaires:
It worked...but...3 days later it did it again....don’t want to keep shutting breaker off
par Sal
Always run the disposal before washing dishes.
Removing the filter allows you to clean it thoroughly.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 74
