Aller au contenu principal
Guide de réparation pour les ordinateurs de bureau Dell.
443 questions Voir tout
I am a novice have a question about startup on my desktop
I installed a new hard drive keep getting this note “ floppy diskette seek failure f1 to continue”. That is where I am stuck. can anyone give me help on what do next? I have read about setup. Do not understand Bious.
Répondre à cette question J'ai le même problème
Indice 0
3 commentaires:
Add a picture of your home screen BIOS please.
par
Sorry I am a novice do not know how from my PC that I can not open .
par
When you first turn on your computer, you will get a dell logo with some text on the bottom, can you rewrite it here ?
par
Ajouter un commentaire
1 Réponse
Floppy diskette failure is not limited to the floppy disk drive. It's typically indicating that your drive is not being recognized. Meaning your hard drive is either dead, or a cable came loose from the hard drive.
When going into BIOS even though the drive is dead it will still show up because there is a small file in the drive that contains the drives manufacturing information. But you might notice that where it says SIZE OF DRIVE it will say UNKNOWN. If this is so, the drive is dead.  And you will consider replace the drive, or if you need info off the drive, you may try recovering files from dead external hard drive.
F2 is normally the key to get into the BIOS settings. Press "F2" when the first screen appears. Timing is difficult, so you may wish to continually press "F2" until you see the message "Entering Setup." Look for the first boot device, and make sure it's set as the hard drive. You can also disable the floppy drive while there.
You can also try change the boot order so that the hard drive is listed first or otherwise before the Floppy Disk Drive.
The boot order should be as follows.
First priority - Hard Drive
Second Priority - CD ROM drive
Last priority - Floppy Disk Drive
Important: Modifying BIOS/complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of BIOS/CMOS settings can be solved. Modifications of the settings are at your own risk.
If the issue persists, I would suggest you to contact Dell Support for getting any further assistance.
Dell Support: http://support.dell.com/
Dell Drivers - Product Manuals & Warranty Info (left side) - Tech Support and more
http://support.dell.com/support/index.as...
Dell Forums
http://en.community.dell.com/forums/
Indice 0
Ajouter une réponse
Gordon Stoa sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 55
