Anybody know what the problem is?
hello, my nicely watched macbook pro 13 early 2015
one day just turn this no water no anything. If I plug into external monitor with hdmi the picture is great and everything works.
It appears your display has failed. Do to the high cost of a replacement unit, I would first try calling Apple and ask them what a “Flat Rate” Depot repair would cost.
1-800-MYAPPLE
If you don’t mind please come back and tell us what they quoted you
The T-CON logic at the very bottom of the display has failed.
That means I can only replace the logic board of lcd and I will fix the problem?
@luka11lavric - Just to give you an idea how difficult this is MacBook Pro Retina Display Teardown its just smarter to replace the entire display assembly than trying to replace the LDC panel!
Jump down to Step 9 the T-CON logic board is that little strip hanging off from the panel which you can't replace. It does the work of sending the signal to the panel.
I often encounter corrosion damage as people use a spray cleaner on the screen which then drips down. The proper way to clean the screen is to spray the cloth with the cleaner so you don't get any drips!
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 39
