Aller au contenu principal
HP released this ergonomic laptop (model number 15-au123cl) in October 2016. It features Windows 10 and a touch screen.
Questions au sujet de 14 Voir tout
If I wanted to install a thunderbolt port, how would I do so?
I want to remove a USB port and instead install a thunderbolt port with a Thunderbolt chip from HP as well. I wanted to do this from the I/O, and remove the USB 2.0 slot.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
That model laptop already has two USB 3.1 ports according to HP’s web site, which support Thunderbolt 2 speeds via a dongle, as long as the data is only moving one direction.
As far as replacing the USB 2.0 port directly on the system board with a different port, that’s pretty much impossible because the connector from the board to the I/O port is pretty different between USB 2.0 and Thunderbolt 2, and Thunderbolt 2 and 3 also need a controller chip in order to function properly. Also, Thunderbolt runs through PCI lanes and the I/O board is probably not assigned any at all, because USB handles data differently.
Thunderbolt in general is kind of a mess, and unfortunately while it’s useful and fast there really isn’t a way to add it to a laptop that doesn’t already have it without replacing the system board and hoping everything still fits.
Indice 2
2 commentaires:
But what if I want to change usb-c for thunderbolt 3?
par
You'd need a way to assign PCI lanes to the Thunderbolt controller, which would unfortunately pretty much mean a full motherboard/BIOS redesign. Just not really something you can do, unfortunately, even though the connector is the same. It's that dang controller chip Thunderbolt needs.
par
Ajouter une réponse
Tyrell Compton sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 25
Total : 459
