Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Repair guides and support for the Expedition, a full-size SUV based on Ford's F-150 pickup truck. Closely related to the Lincoln Navigator.
theft light only lights up for two minutes then off. Why won't it star
Okay so I have a 98 Expedition and I lost my only key so I had to drill out the old ignition in order to get it to the on position to take the cylinder out. In the process the Pats transceiver that goes around the lock was damaged. So I go to pick a part grab another transceiver, installed it i got a new ignition with two brand new chip keys installed and I go to turn it on and it won't start. ot turns over but won't start. I read How to cycle in and program two new keys. In that description it says the anti-theft light will continuously blank for 15 minutes. My theft light will only for 2 minutes then shut off. I figured if I wait till it shuts off will try to start it then but it still won't start. And the theft light will not come back on until I turn the car off with the key and turn it back on and then it'll come on for 2 minutes and then shut off again. what do i do?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
2 minutes is your tell tale sign, you got the wrong part number for your transponder, go to the dealer and make triple sure your VIN number and transponder part number are made for each other. Just tell them this one is wrong please. Also make triple sure you didn’t damage anything else down there.
Indice 0
1 commentaire:
i found the exact same part. same exact part number. now the light blinks for 15 minutes. I have read how to cycle in a new key but battery keeps dying. while i was trying to program a new key it started beeping 5 times five separate times. what's that?locksmith said he'd program or for $50. hope it works.
par
Ajouter une réponse
Alex Pittock sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 1,188
