Aller au contenu principal
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
Questions au sujet de 324 Voir tout
Cant Fix White Screen
Hello, I have recently cleaned the hard drive on my imac and before I could ever get to reinstall Mac Os whenever I turn on the imac, a white screen pops up and I cant seem to remove it. Iv tried doing what I can and im stumped, I am not sure about the exact model of the Imac so i chose one that the photo looks similar too, iv tried holding command r, command r with option and all of those things but nothing seems to go to any screen but the white one. Any input would be great, i have a flash drive that i used TransMac to install a dmg of the MacOs but I dont exactly know how to use it and if I can when its in the white screen
Thanks for any help.
Répondez à cette question J'ai le même problème
Commentaires:
Look on the bottom of your stand you'll find a label with your systems S/N. Plug that into here EveryMac - Look up. Once you know let us know the exact system.
par
It is the Apple iMac "Core i5" 2.8 27-Inch (Mid-2010) Sorry for the confusion I wasn’t the original purchaser so I don’t know many details, I’m just helping out the person who used it for their business
par
No problem! You got us the needed info to get you going. Review @mayer 's answer as your likely have a bad drive.
With a USB keyboard you should be able to boot up in diagnostics. Restart your system and press the D key are you able to and if you are did you get any error messages?
par
It launched with pressing D and it was ent into internet recovery then it gave me the error Apple.com/support -3403D
par
Not to worry. That just tells us you have newer firmware which Apple broke the onboard diagnostics ;-}
par
Voir 9 commentaires en plus
Ajouter un commentaire
Fix Kits pour Android
Remplacer l'écran ou la batterie est à portée de kit !
Acheter maintenant
Acheter maintenant
1 solution
Réponse la plus utile
Your hard drive is failing. To confirm boot up from an external USB drive with El Capitan or lower. Here’s the guide on replacing it:
However if you do this without the OWC heat Sensor you will get run away fans. So you also need to install this:
https://eshop.macsales.com/item/OWC/DIDI...
Remplacement du SSD dans l'iMac Intel 21,5" EMC 2389 EMC 2428
Cette réponse est utile ?
Score 2
Ajoutez une réponse
Casey Coen sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 93
