Aller au contenu principal
Mis sur le marché le 21 septembre 2018. Modèles A1921, A2101, A2102, A2104. Disponible avec GSM ou CDMA / eSIM ou nano-sim / 64, 256 ou 512 Go / Argent, Or ou Gris sidéral. (Se prononce "iPhone 10 S Max".)
Questions au sujet de 311 Voir tout
iPhone XS Max restarts every 4 minutes after screen replacement
I have an iPhone XS Max that appeared fine after a screen replacement. The screen is aftermarket, and the phone now restarts every 4 minutes. Everything seems to work fine in those 4 minutes, battery charged, cameras work, touch works, receives texts, makes calls. Is it just a bad screen? Already tried updating all of the apps and even restored the phone. I have the phone coming back in and will put the original back on to see if that fixes it. Any ideas?
Répondre à cette question J'ai le même problème
Indice 4
7 commentaires
update: phone came back in and original screen did not fix the problem. Have tried to restore again, and use TenorShare to fix any issues software wise. Still no luck.
par
Any update on this issue?
par
Still no updates or answers from anyone
par
Welcome to the modern times of aftermarket screen replacements.
par
Hey Matt,
I used to work for Apple and am assuming you did the screen replacement at a place that wasn't through Apple. You mentioned you already got the original screen back on which didn't help to fix the restarting issue. Is that phone still under the original 1 year warranty through apple? I assume that you didn't get Apple care otherwise you would have done the screen replacement through them?
par
Voir 2 commentaires en plus
Ajouter un commentaire
2 Réponses
Réponse la plus utile
The charging flex cable might have been damaged during screen replacement. Or you can also check the USB IC as mentioned in the repair guide here.
A rare case of iPhone X Keeps Restarting - Motherboard Repair
Indice 2
change the frames 100% worked!
Indice 0
1 commentaire:
What do you mean change the frames
par
Ajouter une réponse
matt mocciola sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 34
Total : 3,783
