difference between lm270wg1(sd)(f1) and lm270wg1(sd)(f2) lcd
or can I use another type, my screen is black but it is not the graphics module. (shining with a strong lamp I see the icons)
Thanks for any solution
Update (10/15/2019)
So, i must replace the whole motherboard (
). Is there and layout of the connector (power)?
1 commentaire
Sadly, your logic board does need repairs. Replacing it would be anther option.
If you had opened the system to alter your drives and you encountered this afterwards I would also check the power cable.
par Dan
