Aller au contenu principal
This is the 8-inch version of the smaller Fire 7. It includes 1.5 GB of RAM, a faster processor, and an HD display. The Fire HD 8 was released on June 7th, 2017.
Questions au sujet de 18 Voir tout
Can someone please help me locate correct USB charging port?
Can someone please tell me where I can get the correct USB port replacement for this device? I have ordered them off of eBay two separate times now and both times they have been incorrect. If anyone can help me locate the 100% correct charge port I would be very appreciative. It is for the 8th Gen model #L5S83A. Thanks, I have waited too long to fix this tablet already.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
Do you have a picture of the charger port top and bottom? I can link you a compatible charger port once I see the pictures.
Is this soldered onto the main logic board or on a small daughter board?
par
Ajouter un commentaire
1 Réponse
Solution retenue
Ben
Unfortunately that link Jayeff posted is to a USB port for the 7th Gen Fire HD 10 USB port. The correct one you need is this: Fire HD 8 L5S83A 8th gen USB port Also if you do a search for USB ports using that model you will find more of the same incorrect ports which you said you already purchased twice already. This is the only one I found that has the correct port pictured. Looks like they used a motherboard to show them matching side by side.
Hope this helps.
Best
Richard
Indice 2
2 commentaires:
Yes, that is the correct model. Thanks so much I have ordered one and am glad someone could point me in right direction!
par
Ben
No problem. Glad I could help out. I notice a lot of sellers listing the wrong USB ports and I mean most or almost all of them.
Richard
par
Ajouter une réponse
BEN sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 655
