this is my problem
first problem of my corolla Toyota is grounded, the battery is becoming weak when engine stop. i used to recharge my battery everyday. when i start, it will start, but when i did not start the engine within three days, the battery would weak and cannot afford to start the engine. until now ,its about one month that the engine did not start. please advise me on how to repair
i dont know on how to answer my question.
par Teodoro Achas
Hi,
If you can charge your battery enough to start the car, once the car has started use a Voltmeter to measure the voltage across the battery terminals with the engine running.
It should measure between 13.8 -14.5V DC.
If it measures less than 13.8V DC then there is a problem either with the car's alternator or voltage regulator and the battery is not charging when the motor is running.
If it measures more than 14.5V DC it is overcharging the battery which could damage the battery.
Be safety aware when you do this as the engine is running!
Also ensure that the emergency brake (hand brake) is firmly applied
par jayeff
My Engine not start.please help me
par Shanto Chowdhury
