Right side of TV going dark.
I have a model UN60F8000. Is there a way to fix this? From reading some posts on here I'm hoping is a bad led strip but I'm not 100%. If it is how /where do I order from. Thanks!
Hi @pistol357 ,
for 99% it will be the LED Strip on the TV. Easily check this fact by removing chassis and power on your TV. If it’s a fault, remove the strip and search for the PN to order the same, if there will not be any information about part number (it have to be), you can order the alternatives from the eBay or Ali express, but choose carefully, read the specs of your led strip to order same, and I’m suggesting you order 2PCS, because the shine will be never same in non-original parts.
@pistol357 yes it is possible that this is a LED backlight array fault. The other thing is that it is the power board not delivering the proper voltage to the array. In order to obtain the proper backlight strips you will need to use your panel number and do a search based on the LCD panel.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 38
