Aller au contenu principal
Do I need a new hard drive?
Ok so i think I damaged my ps4 by leaving it on for too long and it’d over heat. The issues I’m having are the ps4 shutting down when I try to load any game and getting a message saying the software is corrupted. I’ve tried many times now rebuilding the data base and even initializing it as well but still nothing. Do I need a new hard drive? Or anything else?
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
2 solutions
Réponse la plus utile
Hi @ramirezchris64
If there are no important data on this hard disk, you can remove it and test it on a PC.
most hard disk manufacturer provides their in house software to test HDD.
you can download and test it.
Since SSD (Solid State Drives) price are reasonable now, I would suggest you to get this instead, which I recommend for replacement, as for reliability and speed. Brands like samsung, micron should be good.
I will also get this enclosure for standby.
https://www.orico.shop/en/orico-hard-dri...
Cette réponse a-t-elle été utile ?
Indice 2
Commentaires:
The one I recommend to check hard drive health is hard disk sentinel.
If the drive reports any weak or bad sectors on the program the hard drive should be replaced.
In the rare case that it comes up with just 1 weak sector this can actually be reused without needing hard drive replacement.
par
Yes, you need a new HDD, preferably solid-state. I’m going through the exact same thing and the best thing to do is take out the bad HDD and leave it alone until you can clone it to an HDD of the same or bigger size. Chances are, the new HDD will inherit the corruption, but a database rebuild should do the trick, although you may lose some data in the process. Make sure to back up all your data beforehand, if you can.
Indice 0
Ajouter une réponse
ramirezchris64 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 35
Total : 1,355
