Aller au contenu principal
Sorti le 19 septembre 2014, cet iPhone avec un écran de 4,7 pouces est une version plus petite de l'iPhone 6 Plus. Identifiables par les numéros de modèle A1549, A1586, et A1589.
4994 questions Voir tout
Screen only shows low battery after repair
I did a repair for a friend a while ago but it never fully completed because the screen wouldn't come on. The phone vibrates when it's turned on and touch ID works, it's just that the screen never shows anything else but the low battery symbol and that you should plug in the charger. Even after letting it charge for a while the screen still won't come on. I'm wondering if the screen is faulty or if there was a mistake I made while installing it. I have taken the connectors for the screen out and put them back in, the same thing with the battery to no success. Any advice would greatly be appreciated, thank you.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
3 Réponses
Solution retenue
If you see the low battery symbol that proves the screen itself is working and the problem is with something else. Either you have a bad battery that doesn’t take charge, or current doesn’t get to the battery to recharge it. Trying a known good battery would be a first step. If that doesn’t change the picture it might be a bad charging dock or a faulty charging circuit. Double check all relevant connectors too, with some magnification and good light.
Indice 1
please check whether your charge flex cable is installed well.
Indice 1
Might be the issues of middle pin of the battery check it first.
Indice 0
Ajouter une réponse
Jerry Wilkie sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 90
