Hi @sammyhagar ,
As a start, disconnect the power from the TV, remove the back cover from the TV and then disconnect the cable that runs between the power board and the mainboard.
Reconnect and switch on the power to the TV and check if the TV backlights come on and stay on. Obviously there will be no picture as the mainboard is disconnected.
If the backlights come on and stay on then there is a problem with the mainboard or the connection between the mainboard and the power board.
if the backlights don’t come on or if they come on and then turn off and then turn on again or come on, turn off and then stay off then there is either a problem with the power board or the LED backlight strips, cable connections etc.
If you have a DMM and know how to use it, you can measure the voltage being supplied to the backlights at the LED connector on the power board.
It should be a very high DC voltage (possibly 200-300VDC) if the backlights are off as there is no current flowing through the LEDs.
If the backlights are off and you are not measuring voltage in this range but a lot less if any, then there is a problem with the power board.
If you do measure voltage this high with the backlights off then there is a problem in the circuit from the power board to the LED strips. You will have to gain access to where the cable from the power board to the LED strips disappears behind the back of the screen and then use an Ohmmeter (power totally disconnected from the TV) to test for continuity in the wires from the power board through the LED power cable to most probably a distribution board where the LED strips are connected to and then on to the LED strips, looking for loose connections and dry solder joints.
A voté
Annuler
Indice
3
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
