ASUS FX504GM hinges is broken. Any teardown of the screen available?
So, my left hinges of ASUS FX504GM was broken due to impact while moving. I was turning around, the laptop inside the bag, and the left hinges hit with a wooden door.
When i opened up the back cover,unscrewing it all (teardown), bits and pieces of plastics was found. The hinges was never the same,
It wobble at times when closing and now it is in dire state as it create a crack sound (?!) every time i lift the screen up. It is a sound that you usually heard when you try to pry open the back cover. The LCD bezel was bending and opened a bit at the bottom left corner when i try to lift the screen up. That’s where the sound came from.
Now, i wouldn’t even dare to close the screen (flip it down) as the hinge became stiff and the bezel would pop open a bit.
So, i’m looking if there is a video out there that shows how to open up the screen/hinges part or repair/replace it? (please, share the link.it would mean a lot!Thanks!)
or
this question itself is worth to consider for making a guide video on how to replace/repair/teardown the screen part. The available video mainly shows teardown of the board parts and none of the screen parts. (for ASUS FX504 that is, not sure on other model)
Either way, it would help a lot if any solution is available.
Thanks in advance! Cheers~
I have a very similar question and would appreciate an answer. My screen is coming apart at the seam where the red meets black in that same bottom left area. I was wondering if Itd be possible to drill a small hole and insert a wire to twist and hold it together?
par Dylan Rudolph
I am having the same problem as you Dylan, the back of the screen by the hinge is coming apart and i have to manually snap it back in place when opening and closing laptop
par houston_countrygirl
I am also having the same problem,the back of the screen by the hinge is coming apart while opening and closing the lid at the right hinge area. Can you please solve this problem with a video? It would be really helpful for me and them also.
par Ritam Kumar Paul
Hello from Argentina, I have the same problem: left hinge broken, but I have not hit it, so I'm upset and worried about my notebook. Please if anyone has a solution, share it. Thanks a lot
par Ramiro Grande
My right side hinge is also broken for no reason. My friend who also using the same laptop had the similar problem. This laptop is actually sucks.
par Marul
Voir 4 commentaires en plus
