Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Seconde génération d'iPhone. Modèle A1241 / capacité de 8 ou 16 Go / dos en plastique noir ou blanc. Sa réparation est plus simple que celle du premier iPhone. Nécessite des tournevis, un outil pour ouvrir et des ventouses.
horizontal 'lines' on screen, after a slight 'knock' to back
Hi, I recently managed to knock my phone against a low post in the street. I knocked the back of the phone whilst it was in my pocket.
I've now noticed that there 'lines' at the bottom of the screen - I assume this is possibly due to a dodgy connection to the LCD matrix?
1. Do you think it's fixable [no other visible 'damage' to the screen?
2. or is it possible damage to the logic board?
The 'lines' are on every screen and have the same colour - dark blue? They are even getting longer, though I don't use the phone now?
Thanks in advance for any help - compassion ;^)
Répondu ! Afficher la réponse J'ai le même problème
Indice 8
10 commentaires
The bottom of my screen has grey horizontal lines which stay still. However I have dark blue lines on the top of them, which is duplicating the image behind it, and also moving
par
Black horizontal lines are spread all across my phone screen why?
par
Thin black horizontal lines which on my screen is it permanent or we can solvents it
par
Mine has light blue vertical lines that click stuff when they want to and it gets annoying
par
I too get a black line at the bottom of my tablet what should l do ???? Will it remain like that?
par
Voir 5 commentaires en plus
Ajouter un commentaire
8 Réponses
Solution retenue
This could be caused by two things.
One - LCD connection has come loose.
This is the simple and free cause as all you have to do is take the digitiser (screen) off and re-seat the LCD connection. If this fixes the issue i would highly recommend buying some Anti-Static Kapton tape. This tape is high quality electrical tape with strong adhesive and heat tolerance.
Polyimide Tape
Two - The LCD has been damaged
This is the harder and more expensive cause as the LCD has been damaged. As per the name LCD (Liquid Crystal Display) if it is knocked or bumped hard enough it causes the "liquid" to displace itself possibly causing those horizontal lines you now see. However all you will need to do is replace the LCD and you will be good to go.
Here is a link to the part you will need to buy
Here is a link to the guide you will need to replace it if you do not know how.
Hope this helps :D
Image Replace the LCD in an iPhone 3G and fix a malfunctioning display. The display is only the internal LCD panel. The front glass digitizer touch screen and the metal backing plate are not included.
Produit
iPhone 3G Display
$29.99
Image 108 foot rolls of Polyimide tape. Perfect match with OEM Apple Part# 922-1731 tape. Half-inch (.5") width.
Produit
Polyimide Tape
$9.95
Indice 5
5 commentaires:
I have a iPhone5s and it has black lines at the bottom and my screen won't work. What could be wrong? Could it be bcz I dropped it or banged it on something
par
hi,
my Iphone 8 fell yesterday and the protector screen broke, however it has no damage on the actual screen.
but there is two vertical lines underneath the screen now and the touch screen is not working over those two lines.
do i need to replace the whole screen or how do i fix it?
par
I have iphone 7plus got a single yellow vertical line touch is working
par
mine has horizontal lines on the screen. how much does it cost to fix it if i take it in to a repair shop?
par
Hi I just put my phone on my desk and the next morning I find it with black lines and I can’t do anything I’m scared pls help my mom will kill me and do I lose my tik tok account to
par
I had the same issue on an iPhone 4S and I fixed it by warming it up to body temperature for 30 minutes or so. The lines gradually disappeared!
Indice 5
11 commentaires:
my phone has also horizontal lines at the bottom... is it really working by warming? many thanks!
par
surprisingly useful!! thank you!!!
par
how did you warm the phone
par
I held it between my legs :)
par
So, you didn't have to replace the screen? My iPhone 5s has the same issue and I don't know what to do. I would appreciate any advice
par
Voir 6 commentaires en plus
help me there is a small blakcl ine on the right screen on my iphone 6 :(
Indice 2
1 commentaire:
Same to me though...
par
Hmm.. It depends on the lines. If they're black, it's usually the lcd. If white, then it's an issue with the digitizer. Yes, it can be repaired. If their white, you can try reconnecting the display cables, and cycling the battery. If black, you can easily replace the lcd, on that phone
Indice 0
4 commentaires:
It was a very helpful tip n I found the problem is with digitizer. Now the phone is working fine. Thanks
par
My lines are purple And i found them only in my camera please tell me what should i do?
par
What about purple all over, it comes back and leaves
par
mine was a series of green red black lines going downward then just quit
par
i need help. Currently my phone is black(bottom part of it) and the top part is mixed with purple dots and i cant fix it.I tried a the power method and such but i still couldnt make it work. Please help. (Samsung note 4)
Indice 0
3 commentaires:
You need a new display assembly,-/. Your lcd is damaged
Galaxy Note 4 Screen
Remplacement de l'écran complet du Galaxy Note 4
par
My iphone5s some unresponsive touch .it cause a black thin horizontal lines on bottom.it increase while using brightness.what is the problem how to fix ?any body give idea please
par
My iphone 8plus has verticle lines and screen seems a bit deem then it used to be. Text also reflecting back on screen like copying of it. Not damaged or fall on ground for sure. Please advise. Does apple cover if its under warranty to fix it?
par
I have a Samsung 8+, just recently, I noticed a black horizontal line on front camera ( unable to do selfies ) what can I do ?
Indice 0
i have iphone6 which displays on and off showing several horizntal lines….what exactly issue is?
Indice 0
If these will be any physical damage then it can't be fixed. Replacement is the only option to solve this problem. If it happens because of any software issue then update your smartphone this may solve your problem. Either there is a another solution older saver some users clam that they have solved their problem through it.
This may bring life to your dead, stuck pixel of your display. Better give it a try.
Indice 0
Ajouter une réponse
binaryop8 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 58
30 derniers jours : 238
Total : 409,869
