Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La Surface Pro de 6e génération, commercialisée en octobre 2018. Disponible en gris platine et en noir. Numéro de modèle : 1796.
Why is my device not charghing?
So my tablet is plugged in but is still not charghing.My biggest problem it’s that it shutted down before I could try to solve the problem from the settings.Can someone please help me to figure out what it’s going on?Should I buy a new charger?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
@secretgirl I would not just go ahead and replace the charger just yet. Measure the output of the charger with a multimeter and see if it has the required voltage. If so, not reason to replace it. If is does not then you replace it. After the charger you will have to check the charging port. Check for debris, corrosion, bend pins etc. Clean it with a few drops of 90%+ isopropyl alcohol and a few puffs of canned air. If that does not resolve it you will have to take your Surface apart. There you would need to check your charging port connector as well as the power management IC. Even so this is not a guide, it’ll show you what you are up against. So, start by checking the charger first.
Vue éclatée de la Microsoft Surface Pro 6
Indice 2
Ajouter une réponse
Secret Girl sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 16
Total : 526
