Aller au contenu principal
Version revisitée de l'iPhone 3G avec une vitesse de traitement plus élevée. La réparation de ce modèle est similaire à celle du 3G et nécessite de simples tournevis et outils pour faire levier. Modèle A1303 / capacité de 16 ou 32 Go / coque en plastique noir ou blanc.
1500 questions Voir tout
Can I test a new charger dock(picture attached) without tearing down?
Hi
I have 32GB of old pictures on my 3gs iphone but I remember my phone stopped charging years ago and it had issues with charging dock(disconnecting/loose connection ) and suddenly stopped charging and when battery drained it never charged and powered up again.(tried many cables)
so my question is Can I test a new charger dock (picture attached) without tearing down the whole phone and mainboard and just connecting the charging dock connector(cuz it’s right under LCD when I open the phone. no 4) and backup my photos cuz i dont need the phone anymore?
this is the thing im gonna buy to revive my phone :D
Update (01/25/2020)
@imicrosoldering so i’ve done what i said before like the picture below but failed to start the phone :/
and i didnt find a good battery to replace it and test again.
Is it important to solder 2 tiny points in the picture?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
You should be able to do this as long as you get the two connectors to fit properly.
A word of warning.
·         Install a new battery
Do not attempt to use no battery or the battery you originally had. This is an old phone and you don’t want to take the risk of a faulty battery sending error data to the CPU, it could cause the phone to want to update. This scenario would probably be a deal breaker if your storage is near full.
Indice 2
6 commentaires:
Tnx for your answer.and about 2 connectors u mean microphone and antenna(right side round shaped connector) and charging connector(left side)?
Oh And tnx for your warning i’ll replace the battery if I find one
par
You only need to connect the dock and screen connectors.
par
My 3Gs battery is fine and it's never been replaced - granted I don't really use it much because 2G/3G is dead in the US, but that may be an issue in other countries where 4G isn't the standard.
par
@nick Yes it could be fine. But it is a data recovery exercise and with that many photos on the NAND an update to IOS 13 would probably end up with error 14. That is why we wouldn’t want to take a chance and give the phone an excuse to start boot looping and end up having to do an update.
It is better to be safe than sorry when it comes to data recovery. Sometimes you only have one chance.
par
@imicrosoldering oh okk i’ll give it a try
par
Afficher 1 commentaire en plus
Ajouter une réponse
Mohammad Saghi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 78
