Will iMac run without digitiser?
Hi. So I have a 2011 21.5” iMac. It works perfectly fine except the screen won’t light up but if I connect the iMac to my TV I can see on the TV. So what would be causing my screen not to work? The screen itself is not faulty as I have 3 other lcds which I have tested and they all work. Would this be the digitiser? What would be causing it not to show up?
Ps. All the ports on the logic board are fine so it’s not that.
2 commentaires
iMac's doesn't have a touch screen which was a 'digitizer' is used for to identify where your finger or stylus is located on the screen.
Your display does have a backlight to light up the LCD from behind so you can see the screens image.
par Dan
Okay. So you think it would be the LCD backlight preventing the screen from lighting up? Are there any other things that could cause the problem? Anything helps. Cheers @danj
par Quinn
