Aller au contenu principal
Support and repair information for Beats Solo3 headphones.
Questions au sujet de 52 Voir tout
Can I replace the ground wire by cutting and reattaching
Can I cut the ground wire for both sides where it has frayed and reconnect or do I need to replace the wire
Update (02/19/2020)
it’s right before they connected all other wires with the black tubing it’s worn from use and also do I have to softer it? Can I tape it or a another way
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
@arobidoux sure you can. You did not tell us where it needs to be connected so we cannot provide you with more detail. Sometimes a picture is worth a thousand words Ajout d'images à une question existante
Update (02/19/2020)
Alexarae Robidoux  thank you for the images. You could cut the whole first couple inches of the wires. Then remove the insulation from the wire for a couple of inches and and resolder the new strands t the connectors. You may lose a few inches of the total length but at least you would know that the wiring is good. Apply either some shrink tubing or some liquid electrical tape after.
Yes, soldering is really the only way to make sure that the cables are completely connected and stay that way.
Indice 2
Ajouter une réponse
Alexarae Robidoux sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 20
Total : 594
