DC-IN socket on motherboard burnt as well as cable (photo)
It still charges for couple minutes and then stops.
It happened while was I gaming and charging the laptop at same time, all of sudden it would stop charging and later I tried again, it worked for couple minutes and stopt. Then I opened laptop and found out this.
Any help would be appreciated. The laptop was bought in USA but I am in EU in case it has anything to do with parts.
5 commentaires
Hello,
I have the same problem. I would like to know if you found the keyword or the name for the connector in the motherboard?
Thanks
par Frédéric Settama
Hi mine was burnt really bad too but I just bought a new cable cheap online and put it in and worked fine no preformace difference too. Its the only way to fix as I couldn't find a new dc jack which on the board . Also even if some pins break it will still work
par madasar_ali
Thanks for your reply. I will try :)
In the connector there are some parts of the old connector I don't know if I can clean them correctly.
Hey guys could you share the link to the cable replacement. I’ve only been able to find one for the older models that have a different charging port.
par blposey16
https://www.ebay.ca/itm/Razer-Blade-RZ09...
If you need the housing I can link you the housing
par Elusive
