Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The Roomba Red 4100 is a vacuum cleaner robot produced by iRobot that can clean a room all on its own.
Cleaned machine, still not working?
When I turn my roomba 4100 series on, I get the 4 beeps, which indicates that a wheel motor cannot run. I have cleaned all parts and removed any debris. It still beeps 4 times. There seems to be nothing stuck around the wheels or brushes. Help!
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
nicole, turn it over and look for something caught in the wheels. Test wheels by pushing them in and out and making sure they rotate freely. Of course, if you have already tried that and it did not give you any results, then you need to try to run the self diagnostics. Here is link link to a really good site that will show you how to run diagnostics on your Roomba. It should help you to narrow your error down. Also check this link for more info (you are not alone with that problem:-) download the service manual from here. Make sure you save it, apparently iRobot does not like us to look at their manuals :-) Good Luck
Indice 2
how to reove battery how to charge
Indice 0
1 commentaire:
davidgetchen, click on the link on the right side of this screen "Ask a question" and give as much DETAIL as possible for your ROOMBA. Model and serial numbers are very important as well as letting us know what you have tried to fix it. Also let us know what the symptoms are :-) and if you have tried the user manual yet.
par
Ajouter une réponse
nicole sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 17
Total : 2,684
