Aller au contenu principal
Mis sur le marché le 21 septembre 2018. Modèles A1920, A2097, A2098, A2100. Disponible avec GSM ou CDMA / eSIM ou dual-sim / 64, 256 ou 512 Go / Argent, Or ou Gris sidéral. (Se prononce "iPhone 10 S".)
376 questions Voir tout
What is this thing and how do I fix it?
Hi,
This material between the front glass and stainless steel band on my iPhone XS has been damaged from a fall; a bit of it is kinda scraped off. I think JerryRigEverything called it a buffer or something in his durability video for the XS Max. I don’t know if it’s plastic, rubber or composite.
Attached image shows the material I’m talking about. It’s obviously not my phone; I don’t have a camera with me at the moment, sorry..
1) What is this material and what does it do? Is it rubber? Plastic? Composite?
2) How would I go about replacing it? Do I just get a new display? Does it come with a new display? iPhone XS Screen
Appreciate any help. Thanks :)
Image iPhone XS Screen
Produit
iPhone XS Screen
$79.99
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
2 Réponses
Réponse la plus utile
It’s called the bezel, It’s plastic cast around a metal frame, used to reinforce the screen and serves as structural attachment between the case and the screen. It is adhered to the glass with what looks like industrial strength adhesive and the adhesive loops the whole edge of the glass to make a water resistant seal.
Also it is the sealing interface between the screen assembly and the case. Removing the frame is extremely difficult and there seems no reliable way to reattach a new one to seal properly.
You may need to cut open the metal bezel, remove a few structural screw holes, then try to dissolve the adhesive and cut along the display, refer to below video.
https://www.youtube.com/watch?v=syC-HJLj...
Indice 3
5 commentaires:
It's not a bezel, it's a strip of rubber meant to protect from impacts.
par
@yootzmedia no it’s plastic cast over metal frame, it does provide some bumper space between the screen and case, now ever the core structural element is the metal frame, which holds the glass down
par
@tomchai @yootzmedia @jaderichards Is it plastic, or is it rubber? Rubber would have a lower melting point, right (correct me if I'm wrong) ? Thanks :)
par
Plastic. In my opinion, don't do this repair, you'll lose too much for just a cosmetic scuff.
par
Its a hard plastic in my opinion but is the frame of the whole screen tacked onto the inner metal frame of the screen.
par
The piece you are talking about is the bracket that holds the lcd and glass together and holds the screen in place in the phone.
When you replace the screen these are already pre built on the screen. You could choose to replace it but that requires lots of heat and a very steady hand.
Best thing to do is to replace the screen.
Indice 1
2 commentaires:
Is this "bracket" plastic, rubber, or a composite? I'm curious. This could affect how I heat it. Am trying to be careful.
Thanks a lot :)
par
It's a rubber meant to absorb energy from impacts to protect the screen.
par
Ajouter une réponse
Joseph Prekins sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 476
