Aller au contenu principal
Model number LS676 for Boost and Virgin Mobile.
10 questions Voir tout
Why is it overheating and shutting down?
I am very clumsy and I drop my phone in the toilet I quickly got it out and took the battery out and cleaned everything I could up leaving no water I successfully turned on but after a couple of 2-3 minutes though It simply just shut down saying something about over-heating ,you can take the battery out and put back in and it turns on for a couple of minutes or sometimes doesn’t even turn on how do I fix this?"
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Hi
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion is ongoing until it has been properly cleaned away
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion etc. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do check the label to verify the amount of IPA. The higher the percentage of IPA the better.
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here’s a link to the ifixit LG Tribute HD repair guides which may be of some help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Indice 0
Ajouter une réponse
Abril Santana sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 137
