Aller au contenu principal
Le 3a fait partie des téléphones Pixel troisième génération de Google. Cette version budget est équipée de la même caméra que les modèles phare de Google. Disponible en Résolument Blanc, Simplement Noir ou Violet. Mis sur le marché en mai 2019.
Questions au sujet de 62 Voir tout
Pixel 3a screen repair did not work
Hi, I broke my Pixel 3a screen, and ordered a replacement screen from iFixit
After removing the old screen and plugging the new one in, it kind of works, but I get faint horizontal lines across half of the screen. Here’s an image I took of the phone (bad quality, don’t have a good camera on my backup phone):
This photo I found online shows the exact same problem:
Debugging:
  • I’ve tried disconnecting and reconnecting the ribbon cable 3 times, it looks exactly the same each time.
  • I’ve tried power cycling the device a couple of times.
  • Wiggling around the cable / chips at the bottom of the screen unit has zero effect on the problem. It always looks exactly the same kind of wrong.
However, another problem I noticed is that while the screen is the right size, the ribbon cable is about 0.8mm too long. When I lay the new screen flat while plugged into the ribbon cable slot, the screen is 0.8mm offset from the bezel that it should fit inside of:
Did I get the screen unit for the wrong phone somehow? My order clearly says “Google Pixel 3a Screen”. Or is it defective? Is there anything else I can try?
Répondre à cette question J'ai le même problème
Indice 3
2 commentaires:
Same problem here. Have you ever found a fix or did I somehow damage the screen while replacing it?
par
i had this just happen to me as well
par
Ajouter un commentaire
1 Réponse
Sorry, not an answer, and I don’t have the same problem, but I did notice that the original flex cable in my phone had 2 very tiny bends put into it to help the connector ‘drop’ into the slot (the replacements cable is straight). That might explain why yours is 0.8 mm too long.
Indice 0
Ajouter une réponse
Mark H Langen sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 25
Total : 691
