Aller au contenu principal
Processeur 1.86GHz ou 2.13 GHz, Flash Storage 128GB ou 256 GB
147 questions Voir tout
Mac reboots half way to the booting screen - force to hold space bar
Hello,
if anyone can help?
I have a MacBook Air that keeps shutting down half way through the boot process. I am forced to press the spacebar and hold or tape it down in order for the laptop to boot.
I am thinking could be the power button stuck or something but I tried cleaning and nothing.
any ideas how I could fix it?
thanks,
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
3 commentaires
Did you have a liquid spill at some point into the keyboard or trackpad?
par
Hi Dan,
Yeah the wife drop some liquid. I actually disconnected the keyboard and it works.
Is there any way to clean the keyboard or is something I need to replace ?
par
Forgot to mention I check the board and there is no corrosion there nothing
Board is in pretty good shape
par
Ajouter un commentaire
1 Réponse
Solution retenue
Its a bit of work! You can replace the keyboard MacBook Air 13" (Late 2010) Keyboard or if you don’t want to go that deep the easier way is just replace the full uppercase MacBook Air 13" (Late 2010) Upper Case with Keyboard iFixit is currently out of stock but its so much easier!
In either case you’ll need to strip the system down following this guide MacBook Air 13" Late 2010 Upper Case Replacement
Image MacBook Air 13" (Late 2010) Upper Case with Keyboard
Produit
$99.99
Image MacBook Air 13" (Late 2010) Keyboard
Produit
$19.99
Indice 2
1 commentaire:
my suggestion is a replace of the case that includes the keyboard.
or if it an older one that the keyboard is a separate part number - that is fine.
par
Ajouter une réponse
Lex c sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 105
