Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Les vêtements d'extérieur Patagonia vous gardent bien au chaud les jours de grand froid et au sec les jours de pluie. La difficulté de la réparation va de la simple réparation d'une déchirure à la réparation plus compliquée d'un trou dans la construction cloisonnée d'une doudoune.
My Patagonia Rain Jacket lining material is delaminating from shell.
The material that lines my Patagonia Rain jacket is delaminating from the shell. The rubber is flaking off the shell. Can the rubber that provides the water proofing be removed and then the rubber material be replace or is the rain jacket not repairable?
Répondre à cette question J'ai le même problème
Indice 7
4 commentaires
This is happening to my rain gear as well. The net lining in my rain coat also needs to be replaced. Is that possible?
par
Same delamination crap. We paid to much for this to happen so soon. A few rainy days and it's done? C'mon Patagonia...your product was not this poorly crafted in the years past.
par
I have similar. When I take it off it looks like major dandruff all over my shoulders. I wonder if there's some kind of glue type product I could use to seal where it's lifting.
par
I think I have a similar problem of 'dandruff', the Goretex liner in an old Columbia ski jacket with removable fleece sweater. My guess is mine is well over 15 yrs with wear and tear occurring with the Goretex disintegrating. An email to Columbia was sent with a reply of sending the jacket back for examination. Perhaps emailing Patagonia mentioning jacket model, year of purchase and a description of problems may help. Snapshots of liner delaminating too.
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
I ended up contacting Patagonia about my delaminating Torrentshell, and was given a 30% voucher off a new one which is great - once my size is back in stock I'll (probably) get one. I'll make sure to wash it at least annually (with Nikwax Tech Wash).
Patagonia advised that it isn't repairable. And a read across the internet is all of these layered jackets have this issue eventually. There wasn't mention of how to ethically dispose of it, and it's got me thinking about the vast amount of microplastics coming from all these layered jackets :/
To relieve the 'dandruff' effect I washed it, and then used a hard brush on all the areas where it's peeling, and that caused more initially - but got to a point of removing the loose spots and being much less powdery on the clothes for now. Perhaps some sort of adhesive may work to prevent further lifting in the worst areas, but it's going to disintegrate everywhere eventually.
Indice 2
2 commentaires:
I did this and the same thing happened again to my new rain coat. its like you get stuck into paying so much money for a product( repeatedly ) from something that doesn't work. they're supposed to be ethical and environmentally friendly- but the micro plastic that showers off leaves me feeling super disappointed. I wear it a handful of times a year..
par
Really is a shame. I’ve discovered I’ve got the same problem just on my last trip, and it’s really too bad as I love the jacket.
par
Mon manteau imperméable Blue était acheté le 15/09/2015. Il est en bonne état, sans déchirure, mais la couche de lamina intérieur est délaminage en plusieurs endroits . Est-ce que c’est une défaut de fabrication ? J’aimerais avoir votre opinion et votre conseil de quoi faire avec. Merci
Indice 0
1 commentaire:
My Blue waterproof coat was purchased on 15/09/2015. It is in good condition, without tears, but the inner lamina layer is delamination in several places. Is it a manufacturing defect? I would like to have your opinion and advice on what to do with it. Thank you
Unfortunately, there's a pattern of the waterproof lining disintegrating, delaminating from normal wear after some years have passed. Manufacturers are not forthcoming about this. However, we all seem to have long term use of outer wear with good use.
Malheureusement, il existe un motif où la doublure imperméable se désintègre, se délamine à cause de l'usure normale après quelques années. Les fabricants ne sont pas transparents à ce sujet. Cependant, nous semblons tous avoir une utilisation durable de l'usage extérieur avec une bonne utilisation.
par
Ajouter une réponse
Karl sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 87
Total : 8,036
