Aller au contenu principal
Sorti le 25 septembre 2015. Modèle A1688/A1633. La réparation de ce modèle est similaire à celle des versions précédentes et nécessite tournevis et outils pour faire levier. Disponible en GSM et CDMA / 16, 64 ou 128 Go / Argent, Or, Gris sidéral ou Or rosé.
2686 questions Voir tout
Screen very dim after replacement
Guys maybe you can help me, after the screen replacement the brightness of the screen is very very low, almost impossible to see I have to put a light against the screen to see something, what can it be?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi Francesco,
It sounds like the backlight on the screen is not working. This may be due to a blown backlight circuit—which may happen if you tried to reconnect the display with the battery attached and powering the logic board.
You can try to carefully re-seat the display connectors (make sure to disconnect the battery first) to see if that will solve the issue.
Indice 1
1 commentaire:
Thanks, I think you are right, I probably didn't realised when I was connecting the display the battery was still connected. Unfortunately I tryied to re-seat the connectors but nothing changed. Sometimes seems the backlight is coming back, like flashing for one second.
par
Ajouter une réponse
Francesco Bandinu sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 243
