@windydesert
Hi Alice,
Unfortunately this sudden death can be due to many possible causes.
Did anything unusual happen before it died. Over heating, trouble plugging in charger to laptop, lock ups, dropping laptop, liquid spills, flickering screen, etc., etc.?
This is a long shot but have you tried the BIOS reset routine?
Remove power supply/charger, remove battery, unplug or remove the CMOS coin battery and then press and hold power button for 20 or 30 seconds.
This will reset the BIOS to default and hopefully remove any possible corruption. Any lights when power supply plugged in, even for a moment?
Here is a video of a complete "tear down" of the laptop:
https://www.youtube.com/watch?v=ijpVerkf...
also IFIXIT as well for some p0arts:
MSI GP60 2PE Leopard
Take a look around where the power supply/charger connector is on the board. Any signs of wear or damage? Any signs of burning around any components?
Unplug one component at a time to try to eliminate a short. After each removal/disconnect plug in charger and look for any lights. Be careful discharge any static from your body by touching some metal object. Hold components carefully by the edge. The display screen is a good one to start with, then WiFi, hard drive, RAM one at a time rotating sockets each time, etc.
It is a start. Good luck. Let us know how it goes. Do everything slowly and carefully. Keep a brief, written record of what ever you do. If unsure, ASK!
A voté
Annuler
Indice
2
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
11 commentaires
Hi Alice,
Does it show any sign of charging when you connect the chord? If it doesnt then maybe you have to wait for a replacement and then you can inform us if the chord still doesnt work.
par Jesse Jit
@Jesse Turi thanks for the reply! No, no signs. No lights, no sounds, absolutely nothing. Yeah, I will wait to the cord. It's just that i have a deadline on my hands and was hoping there is some other possible fix lol.
par Alice
Okay lets get a bit risky. Do you have any kind of tester nearby? If you do you can test to make sure your power chord is not dead. Just be very careful when using the tester to avoid short circuits etc.
par Jesse Jit
@jc_jit okay this might be a dumb question but what kind of testers? Like a multimeter? I don't have one unfortunately.
par Alice
Ahh not really a multimeter though it would have been the most helpful though you can just use a phase tester for now.
par Jesse Jit
Voir 6 commentaires en plus
