Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le NutriBullet, créé par les fabricants du Magic Bullet, est un blender individuel autonome et simple d'utilisation. Il comprend une base de mixage électrique avec plusieurs accessoires pour l'utilisateur et propose une alternative saine au mixage traditionnel en décomposant les ingrédients dans leur état le plus nutritif.
Why aren't the top and bottom wheels locking together?
Both top and bottom male/female wheels supposedly to lock for spinning, aren’t actually locking correctly hence smoke is produced, I would assume due to the friction of an imperfect lock. How to resolve? I’ve tried disassembling from the base but it just seems a hassle of a job considering that I’m not even sure I can find replacement wheels. It seems one of the wheels was consumed by the friction initiated with power on. Help!
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire
I have the same problem... it's the wheels that do not lock in. any help?
par
Ajouter un commentaire
3 Réponses
Réponse la plus utile
I have the same problem, did you get help?
Indice 1
If your NutriBullet blender is making noise but the blades aren’t spinning, see the NutriBullet Blades Will Not Turn problem page for possible problems and solutions.
Indice 0
I had the same problem. But the simple solution was posted by someone, I checked her data and sure enough...fixed!!!!
There is a plastic trim that normally fits on the rim of a blending container to make it into a drinking cup,(smooth edge instead of sharp plastic rim).
This trim piece had somehow dropped into the throat of the blender and when I jammed the drink container into the base it forced the ring down and made it seem that is was an integrated part of the use. Whomever posted the solution had recognized she had "stored" the lid inside the base and of course that extra thickness would not allow the engagement of the gear teeth.
I followed her data, got a mechanics pick tool, pulled out the ring, and No More Problem!!!!
Indice 0
Ajouter une réponse
Mariasole sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 13
30 derniers jours : 28
Total : 933
