Aller au contenu principal
The fourth generation Nissan Altima (chassis model L32A) was announced at the 2006 New York Auto Show on April 12, 2006. It was the first vehicle to use the smaller Nissan D platform, with a new front and upgraded rear suspension.
Questions au sujet de 26 Voir tout
Why cooling fan runs and engine won't start?
My car was running normally then switched off the engine for a few hours, came back and while trying to start again, cooling fan runs, no crank and engine won't start.
All dashboard lights on after single click on start button while pushing breaks (cooling fan runs), which is really weird coz engine is not hot. Another press on start button, everything goes off.
I recently changed radiator and spark plugs + 2 ignition coil.
Any idea what could be the reason and how i can fix it?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
5 commentaires
We’re is the bcm I’m having the same Problem
par
And what all I have to tske off my part car with the same year 2007 to get this one running
par
Help....I am having this same issue. What did you do to fix it?
par
In my skoda fabia it was immobiliser. I just had to disconnect accu (battery) for 1 minute, then reconnect and engine started:)
par
I have the same problem but I have a '94 BMW 3 series
par
Ajouter un commentaire
5 Réponses
Solution retenue
It may well be that the fault with the cooling fans has drained the battery too much, when it tries to start the battery voltage collapses and the electronics give up. Try charging the battery or use a booster pack to get it started, you can then drive it somewhere to get the cooling fan problem fixed - this may well need to be a main dealer with the right diagnostics equipment.
Indice 0
Réponse la plus utile
Mine did the same and it was the engine control fuse. It's in the fuse box under the
Indice 1
1 commentaire:
Under the what? I cant see the rest of the text
par
This usually an indication you have a shot BCM.
Indice 0
1 commentaire:
Where ia this located?
par
I’m have this problem now . The guy look at it he put a used relay on my van and now the same thing is happening. I’m going to buy a new relay and get the battery charged and see what happens.
Indice 0
1 commentaire:
Did you find out what it was?
par
It might be immobiliser. I disconnected battery for 1 min, reconnected it and the car started
Indice 0
Ajouter une réponse
Ahmad Nawar sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 24
7 derniers jours : 149
30 derniers jours : 781
Total : 12,744
