Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Console portable Nintendo sortie en février 2011, s'identifie au numéro de modèle CTR-001.
3D slider doesn't work
I just got my hands on an original (2011) 3DS with a broken 3D slider. The slider itself, well, slides, but it doesn’t change anything. The console is stuck permanently in 3D mode.
How do I fix it? I’m willing to crack open the 3DS as my final goal is to completely fix it and keep it. :)
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
2 commentaires
I have the same problem but it's with the internet slider. I just got the 3ds and I can't use the internet.
par
IMPORTANT Don't format or factory reset the 3DS if the 3D slider is broken because you won't be able to get past the Initial Setup Wizard and the device will be soft-locked until it is repaired. During the initialization you must be able to adjust the 3D settings using the slider and if it doesn't work you can't complete the initialization and the 3DS will be unusable.
par
Ajouter un commentaire
1 Réponse
Solution retenue
Hi Nikki!
I’m affraid this is a hardware fault.. But you could try the simple basics first. Full system reset, check if there is dust inside there, try an air blower ect. Perhaps the slider is not seated correctly to the switch.
The slider have it’s own PCB and is connected with a ribbon cable to the PCB where the speakers are connected. It’s fixable, but it won’t be easy.. You also need to heat the glass panel too.
Tut: Changer l'écran LCD supérieur de la Nintendo 3DS
If you opened it up all the way to the upper LCD, please double-check step 28, step 29, step 32 and step 35, those steps are regarding the 3D slider.
You don’t need to remove the speaker assembly or the LCD it self.
Indice 1
5 commentaires:
Hi! Thanks a lot! Just to confirm: I have to remove the top glass panel and in the worst-case scenario replace the ribbon cable and/or PCB?
par
Your welcome! Yes, you need to go all the way as in the tutorial. But you need to stop at step 27. You can replace the 3D switch from here :). It's connected with a ribbon cable to the speaker PCB. You need to replace the whole 3D switch PCB (it should come with a new ribbon cable too). After it's replaced, build it together and test.
par
@koppie007 One more question, if you don't mind. :)
I'm a bit confused as to where I can buy the PCB. I tried searching on eBay and Aliexpress but I can't find it.
par
Hi Nikki,
Don't worry about it, you can ask all the questions you want, we are here to help :).
Sry my bad, you need to search for the "Speaker Ribbon Flex Cable". Everything is on one cable.
Link: https://www.aliexpress.com/item/32531379...
If there are any more questions, please let me know.
par
par
Ajouter une réponse
Nikki sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 20
7 derniers jours : 85
30 derniers jours : 330
Total : 20,537
