Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Trouvez des informations de réparation et des détails supplémentaires pour le réfrigérateur GE GNE29GSK****, un modèle avec congélateur en bas et portes françaises, équipé d'une machine à glaçons automatique et d'un interrupteur de résistance anti-condensation. Cette page couvre les informations pour les numéros de modèle correspondant au format GNE29GSK****.
GE Defrost Thermostat Location (See Pic)
I took the evaporator coil cover out of my GE Freezer (GNE29GSKSS) to inspect the coils for frost. I was wiping the top of the freezer down and accidentally unclipped the defrost thermostat. Please see pic and let me know if it should attach to the first or second tubing in the picture provided. I reclipped it for the pic but I’m not sure if that’s where its supposed to go. Thanks!
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Hi @mjm05 ,
It should be mounted on pipe 2, not that I think it matters much as in some refrigerator freezers it is mounted on the evaporator itself.
The defrost thermostat operates when the freezer air temperature is ~>32 F (0 C) to signal the control board to stop the defrost cycle and to start the compressor again to cool things back down to 0 F (-18 C).
Indice 3
5 commentaires:
Thanks for the help!
par
And doesn't matter it reaches the temperature of 50° and it restarts the compressor when it gets down around 35 it closes ,so the heaters will work when the defrost timer starts
par
Hi @ tony pennington
If it is a bi-metal thermostat, the specifications should be printed on the thermostat's case.
Operating at ~50°F might be OK because it is measuring the temp on the evap unit or the piping where it is attached to and not the ambient air temp as you wouldn't want the food to even begin to defrost but it should release again at about 25°F to be ready for the next defrost cycle.
It may depend on the thermostat's specs but I think that 35°F is a little high
par
is the switch normally closed or open
par
@elmigo
When the freezer is at normal operating temperatures the thermostat is closed.
During a defrost cycle when the temperature goes above the thermostat's preset temperature upper limit the switch opens. This is so the defrost heater is turned off so as to protect the evaporator unit
Depends on the thermostat but most are closed at temps <25°F and are opened at about 46°F
par
Ajouter une réponse
Mike M sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 46
Total : 2,911
