Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La deuxième génération (modèle de châssis L30) était une version destinée uniquement au marché américain, de nouveau dessinée par le centre de design californien de Nissan sous la direction de Doug Wilson jusqu'en 1994 (gel du design en 1995).
Will turn over no start
I have a 1999 Nissan Altima Gxe 2.4L engine. The crank will turn over but want start. Have already changed the spark plugs, spark plug wires, distributor cap and rotor. I also just changed the valve cover gasket cause it was leaking and changed oil and filter. It wouldn't start before i did the tune up and valve cover gasket change.
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
Yes. Changed spark plugs, spark plug wires, distributor cap and rotor. It wouldn't start before I did the tuneup on it. Would turn over but not start
par
Ajouter un commentaire
2 Réponses
Did you check for spark and fuel? Did you check the timing belt and make sure it was on time? First steps before you do anything else.
Update (06/24/2020)
You need to see if it has spark and fuel pressure. You need to check and see if the timing belt is broken. There are multiple reasons a car will not start.
Indice 0
2 commentaires:
How do you check the fuel pressure
par
My advice is take it to a shop
par
Are you sure the car doesn't have an inertia cut-out, which has tripped (they are designed to turn the engine off in case of accident)? I am not familiar with this car specifically, but the switches are sometimes found in the vicinity of the spare wheel well.
Indice 0
Ajouter une réponse
Sean Harkins sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 22
Total : 805
