Aller au contenu principal
iPhone 4 pouces commercialisé depuis mars 2016 avec une configuration de matériel similaire à l'iPhone 6s. Disponible en Argent, Gris sidéral, Or ou Or Rose, avec 16 ou 64 Gb de stockage. Modèles A1662 et A1723.
1049 questions Voir tout
Vertical bars at top of screen + right side unresponsive - RESOLVED
Hey gang. About a year ago, my GF dropped her iPhone SE in water, and her AppleCare replaced it with a '“new” iPhone SE 1st gen, whatever that means (probably refurbished?)
On this replacement SE, this morning after a call, the right half of the screen stopped responding to touch input. I also just noticed some vertical gray bars starting to appear on the very top of the screen (see attached image), mostly on the right half.
Does it seem like this could be JUST a bad connection between the screen’s flex connector and the logic board? Or does the presence of the vertical banding imply damage to the screen?
Répondre à cette question J'ai le même problème
Indice 0
4 commentaires
Do those bars seem to flicker and move vertically? If so, than a touch IC chip is damaged.
Also SE (gen 1) is the iphone SE in the 5s form factor, the new iPhone SE is basically the X guts in an i8 form factor. Apple’s naming conventions are stupid
par
@Charlie Yarbrough Thanks for your input! The bars don't seem to flicker nor are they moving in the vertical plane. They are quite static, regardless of what drawing is happening below them.
I made a video if it helps diagnose:
https://streamable.com/kdgpce
I'm hoping I can fix this with a simple screen replacement.
par
@r1223 seems to me that the screen assembly is damaged/separating. I’ve seen your exact issue from that. You’ll need a new display assembly (which is a pretty simple repair). Also check your battery from swelling. If you see the screen bowed out or if you push on the display towards the middle-left and see ripples (often accompanied by yellowish coloring) your battery has begun to swell and damaged the display.
It can also happen from drops or randomly becoming faulty later on, but with no physical damage, battery swelling is most likely imo
par
@Charlie Yarbrough The battery seems fine, I didn't notice any warping of the surface of the screen, and pressing on various parts of the screen doesn't produce any graphic artifacts or anything like that.
The phone is a warranty replacement phone that's a little under a year old so it's not an older battery.
I think my strategy here is to order the screen replacement kit & tools, and once I get it open, inspect the battery and hope it's not puffed out. If it is, I guess I'll put the project on hold and get a replacement battery as well!
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
It looks like it just needs a new screen as I see issues like this quite often after replacing the battery in the 5 series. As Charlie mentioned above, I’m not familiar with touch disease being a known issue in the 5 series but it could be a possibility. You won’t know unless you try a new screen. Good luck!
Indice 1
I replaced the screen and this problem went away -- the phone works fine now, good as new. The battery was in good shape, no puffiness there.
As I was pulling the screen up with the suction cup, I noticed that the screen glass wasn't attached solidly to its plastic underlayment, with a slight bit of give between the two layers, on the top-right corner which was exhibiting the vertical bars and touch-screen failure. I'm not sure if this was a manufacturing defect or drop damage, but this is most likely the culprit.
Thanks for all the help!
Indice 0
Ajouter une réponse
r1223 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 50
