Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tutoriels de réparation et d'entretien pour différents types et marques de télévision.
Sharp LC-50LB481U replaced bad LED's, still no backlight!- RESOLVED
Okay I’m back with ANOTHER broken Sharp Roku TV. Model # LC-50LB481U. It had all the signs of a bad backlight- fully functional and you could see the picture with a flashlight. I took the entire TV apart, found the bad LEDs and replaced the strips. After putting it all back together there is still no back light. It seems as if the correct voltage is not being supplied. I can light the LEDs by using my LED tester at the respective harness connector.
I have tested the voltage at the LED harness connector and about 16 volts are being supplied where the LED tester would otherwise supply 59 to bring the LEDs on.
I pulled voltages at the connector from the main board to the power supply (pics below):
Top Row : 6.1V (fluctuating), 3.4V, GND, GND, 12.1V, 12.1V , 12.1V, 0
Bottom Row: 6.7V (fluctuating), 0V (no continuity), GND, GND, 12.1V, 12.1V , 12.1V, 0
As always, thanks for the help!
Back of Power board: A little blurry, I will take again and repost.
Update (07/26/2020)
Better picture of back of power board :
Update (07/31/2020)
Okay after replacement of the power supply board my TV is now operating normally. I am surprised that the TV required both LED strip AND Power Board replacement but it is what it is I suppose.
Répondre à cette question J'ai le même problème
Indice 1
22 commentaires:
@jostewcrew Need your expert eye again!
par
@chillin014 .... heya, from what you have posted... looks to be the power supply board. unplug the connector from the main board and check the power supply side to see if your 5v returns. compare your readings to the original.
pro tip: always start with the power supply board. check voltages against print screen legends for voltages, if off, unplug peripheral boards and check again. if still off, troubleshoot power supply, if returns to normal, plug in one board at a time and check for irregularities to start to hone in on issue.
par
@chillin014 ...lets see the back side of the power supply board.... ill scan the front side in the mean while
par
@jostewcrew You rock!. I will post momentarily!
@jayeff you also rock! That makes sense. So I unplugged the main board connector (with the tv powered on, otherwise it would not power on). The 15 and 16 volt terminals remained the same. They actually read, and have always read, a fraction of a volt (.07 V).
When unplugging the main board connector the back lights flickered on very briefly. I replicated this to make sure I saw correctly. I don't know if this has any significance.
I hope to eventually be able to diagnose down to the component. Would be nice to spend $1.00 fixing a board rather than $30-40 replacing it. The power board components look simpler/easier to solder, the main boards not so much.
par
@chillin014 ... np mate. youll get to be able to do component work soon with the rate youre going. with the right investment in tools, smd work isnt a problem. its all in the troubleshooting. easier with schematic. knowledge will come....quicker than you expect.
while youre posting the pic , afterwards... hook up the power supply one last time. dont connect anything. at the connector to the backlights (unplugged) test the terminals immediately as the unit powers on (power button) record the max voltage reading ( use min max setting on meter) do this for each led + ( you have 3, gonna do it three times) red on +, black on chassis for ground. post your findings while i look over the pic of the back.
par
Voir 17 commentaires en plus
Ajouter un commentaire
3 Réponses
Hi @chillin014 ,
Are the voltage measurements for the connector pins as shown in the last image? So no +5V on either pins 15 or 16 - top row last pin on right, bottom row last pin on right? You have them both marked as 0.
Not sure if the 6.1V fluctuating (pin 1 - top row first pin on left) means to turn off the backlights or to turn on the backlights. The pin is marked as DIM - which would make you think that it might be associated with the backlights. Mind you it may be the same with pin 2, the one marked On/Off
Do you get audio as well as a display (without the backlights)?
If so, it may be quicker to get a replacement power board - example only, than try to figure out what’s wrong with the power board without a schematic. Just a thought
Indice 0
1 commentaire:
@jayeff You are correct, there was no voltages on Pin 15 and 16.
and Yes I do get audio and picture. The only thing not turning on is the backlight. I'm fine with replacing the entire board I just wanted to confirm whether it was the power board or main board.
Thanks for the help!
par
Hi. I just remove the power supply board. I found out that the legend next to the connector and the underside legend are not the same. That was confusing to me. And maybe to others. The picture you show of the power board has the same problem with the wrong legend. I know why your voltages do not follow the legend next to the connector.
I am not able to get the 5volts, only 0 volts comes up. The power to the back-lights is 63volts. I will replace the power board.
Indice 0
1 commentaire:
hi I have a sharp lc-43cug8462ks the backlight is out. I have tested the leds and are all working so I tested the power board and from the plug that powers the leds was getting a spike from 110v to 0.3 volts in about a second so I changed the power board and am still getting the same readings? any help or information would be greatly received thanks.
par
From what I have been reading it sounds like this may be my problem. I have a black screen with no audio. I have used a flashlight and get that I need to sign in and establish an account and other stuff but the only way that shows up is with a strong flashlight shined on the screen. I had a similar problem years ago on this set and was able to buy a lot of parts for pretty cheap and was able to fix it. Now it has done it again and I have used those parts that I bought years ago and changed control board, power board and the dcon board with no results so I guess it is time to try some of what was offered in this. Will let you know Chris just what happens. One thing nice about working on something that is broke you can't break it any worse and any more there are no tv repair shops around.
James Parker
Indice 0
Ajouter une réponse
Christopher Hill sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 36
Total : 8,143
