Aller au contenu principal
Le smartphone troisième génération de la marque Pixel par Google et leur tout premier téléphone "à encoche". Équipé d'un écran OLED QHD+ de 6,3 pouces et d'un stockage de 64 ou 128 Go. Disponible en Résolument Blanc, Simplement Noir ou Subtilement Rose.
Questions au sujet de 72 Voir tout
Mic doesn't work after charging port replacement
I replaced my charging port with an iFixit replacement. After putting back together everything works as expected except for the mic when not on speaker phone. From my research, the mic is part of the charging assembly. I am wondering if I received a defective part? I am going to take apart again in check all connections. I’m wondering if anyone else has suggestions…
Thanks!
Répondre à cette question J'ai le même problème
Indice 3
3 commentaires
Hi. what was the solution for your problem ? have exactly the same problems…..
par
I did another charging port change and the mic works fine now. It's likely the board I received was defective since the connector seemed seated fine for the faulty board. I was able to perform an exchange to receive a new board. After installing the new board, everything works fine now
par
Ok thanks. I think i have the same problem. Ordered new board to test it.
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
I would imagine it’s defective. Disassemble and check the connection. Sometimes if it’s not seated all the way it won’t work.
Indice 1
1 commentaire:
I replaced the charging port with a new replacement and the mic now works. I can confirm that the part I used previously was simply defective.
Thanks for the suggestion
par
Getting another replacement daughter board should fix the problem because some replacement board has faulty mic from factory.
Indice 0
Ajouter une réponse
SEAN BEAUSOLEIL sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 11
Total : 468
