Aller au contenu principal
Pour réparer ensemble - Je crée un compte
SodaStream Source est une nouvelle façon de créer vos sodas dans le confort de votre maison. Elle vous permet de personnaliser vos boissons et de créer uniquement les boissons que vous aimez, tout en éliminant les bouteilles en plastique supplémentaires.
Co2 pours out when I screw in a new canister
Co2 pours out when I try to screw in a new canister. Support rep says I "probably need a new O-ring." What the heck is that, where do I get one and how to I install it?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
3 Réponses
Solution retenue
If you are hearing a hissing noise coming from your SodaStream Source, the carbonation tube is leaking gas, or the carbonation bottle is leaking, use the SodaStream Source is Leaking Gas problem page to fix the leak.
If the SodaStream Source’s sealer washer becomes worn out in the carbonation attachment area, the SodaStream’s carbonation bottle will shift or not hold firm when attached. To remove and replace the sealer washer, use a pair of tweezers to pull the small black rubber ring out of the area where the carbonation bottle attaches to the SodaStream. Replace the old sealer washer with a new washer and try to reattach the carbonation bottle. If the carbonation bottle is attached firmly, the SodaStream Source should no longer leak.
If your SodaStream Source is leaking during carbonation, see the SodaStream Source is Leaking During Carbonation problem page instead.
Indice 1
Cette réponse correspondait à l'origine à une autre question .
We’ve had to warranty our machine twice due to this. The third machine is on its way. Hopefully we’ll have better luck.
Indice 0
I think it’s possibly due to over tightening the co2 bottle.
Indice 0
Ajouter une réponse
T G sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 35
30 derniers jours : 173
Total : 14,245
