I'm looking for a repair manual for a 14.5hp 42' Murray riding mower
The safety switch connected to the blade engagment lever is stuck in the open position,not letting the engine to turn over and start. Would like to locate the switch and either replace it or by pass it.
5 commentaires
do you have a serial or model number?
par oldturkey03
I bought the mower used at the 1st of the summer. The sticker under the seat where the serial # and model # is gone.All I have is the engine model #.It is a 14.5 hp B/S motor 42"cut hydrostatic drive.Murray says they did not make that model tractor so I assume it was made after 2005 when briggs&stratton took over.Think I've located the safety switch on the frame would like to know if it can be bypassed?Thank You.
par Mike
The engine will not even turn over/nothing...just replaced the ignition switch thought that it might have gone bad still nothing.Before ,when it was running ok,I would have to pull back on the blade engagement lever to start it then engage the blades to mow.Then it started shutting off when I engaged the blades/now it will not start at all.Like I've said it acts like the engagement safety switch is stuck.
par Mike
I would like to thank oldturkey and Phillip both for the response amd the advice.I did get the mower running and the grass is cut.I found the switch and was able to replace it for about $17.Thanks again and I'll be back if I ever need anymore advice.Mike
par Mike
Alright, congrats. Good thing you have grass to cut, its all hay down here ;-) Good Job Mike.
par oldturkey03
