Aller au contenu principal
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 questions Voir tout
Question close
Why monitor displays a lot of lines on screen?
After I startup my iMac there's a lot of lines on the screen. Now I am unable to see what's on the screen.
Could it bethe monitor faulty?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
4 Réponses
Solution retenue
Please, connect your iMac on an external monitor and tell us if the video output is normal. It's the first step to troubleshoot a screen issue. The issue could be related to a bad GPU (graphic processor unit) located on the logic board or a screen internal component such as LVDS cable or the LCD panel. You can exclude the inverter and backlight failure if your screen still has lightning.
Indice 6
3 commentaires:
Your answer was so much better than mine that I deleted mine. one up
par
Hi lemerise,
Thank you for the insightful tips.
par
How do you connect to an external monitor?
par
Look at this first then tell us what kind of lines, in what direction, what color and anything else you think we may need.
Wide white lines showing up on display
Indice 0
Hi lemerise,
Indice 0
Indice 0
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 4,507
