Aller au contenu principal
A2115 / 2019 / Processeurs à partir de 3,0 GHz 6 cœurs i5, jusqu'à 3,6 GHz 8 cœurs i9. Commercialisé le 19 mars 2019.
129 questions Voir tout
iMac 2019 27" CPU change
Hello, I tried changing CPU ( i9 9900) and ssd, but after assembling everything, it does not start. I tried searching online what the cause could be, and looking at the diagnostic led i could not find a solution. As you can see from the image there is one led on, and if I understand correctly it is the #2. I tried disassembling again to see if there are some bent pins, but they are all fine. What could be the problem?
Thanks
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Try reseating the RAM first, then the PRAM before taking it apart again. I had this similar problem.
Indice 0
Ajouter une réponse
Max sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 52
