Battery replacement hasn't led to any improvements in battery life!
Just replaced my 2013 Macbook Air’s old battery with a new iFix it battery but I can’t say its made any difference to the battery life so in effect its currently been a waste of money…..please help as surely it should improve the battery life significantly?
Update (01/14/2021)
Dan - I'm not going to risk taking the computer apart again (!).....but here is the image of the new battery via the coconut app.
Update (01/14/2021)
Here you go
Lets take a deeper look at both batteries!
First install this app so we get a better view of things CoconutBattery take a snapshot of the apps main window, disconnect the current battery and plug in the other and repeat. post both here for us to see Ajout d'images à une question existante. Make sure the battery is about half charged and your MagSafe charger is plugged in give it a minute before you take the snapshot for both.
par Dan
I followed the instruction on how to upload an image but it doesn't seem to work - keep getting the image description as per above but no photo. I can see it in the media manager but when I attach to my post it turns to text.
par James Finch
@jfinch73 - The text element is a point to the media container tag, comments was not designed to support images which is why you see the tag and not the image.
Your original post is where you need to post it. Go into Edit mode to add it (review the blue URL link I posted)
The images shows me your MagSafe charger is not connected when you took the snapshot is that correct?
par Dan
Yes the mag safe wasn't connected. Do you need me to take a photo with it connected?
par James Finch
@jfinch73 - Yes need to see it under charge as I explained in my first comment for both batteries.
par Dan
Afficher 1 commentaire en plus
