Hi,
Appears as though there is a problem with the power for the fluorescent backlighting in the display or there is a problem with the display itself.
Here’s an image taken from the service manual that shows the No FL Display troubleshooting flowchart that may be of some help.
Be patient when trying to download the service manual as it takes a little while to go from processing to Download, once you have passed the security check and clicked on Go to Download below the Document preview box
(click on image to enlarge for better viewing)
If it is the display assembly then on p.82 there are part numbers for the 2 displays for your model
PRIM DISPLAY ASSY (SC-LX59) part #AWM8411
DISPLAY ASSY part #AWX2023
I don’t know which one would be the problem but searching online using the part numbers shows no results for the first listed display assembly and this is all that there was for the second, so hopefully it is a display power problem and not a primary display assembly problem or even the other display assembly.
Hopefully this is of some help.
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
1 commentaire
Hi Gary - Did you ever fix this problem?
par Garchiba
