Aller au contenu principal
La version cellulaire de l'iPad Air deuxième génération d'Apple. Modèle A1567.
Questions au sujet de 74 Voir tout
Battery replaced with iFixit kit but doesn’t appear to charge.
Hi, I finally had the courage to gut open the iPad Air 2 that still had an original but dead apple battery.
I followed the instructions on the website, it wasn’t hard but it was just time consuming. The charger is connected but no sign of life. The screen remains black. Does it take a long time to charge and boot for the first time ? How can I troubleshoot and find out if I broke something or if the new battery is defective?
edit: I didn’t remove the adhesive of the back of the battery nor replaced the ones around the bezels for testing purposes for fairly obvious reasons.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Commentaires:
Howdy,
thank-you for taking the time to reply . I followed your advice and redid all the connections but the results remained unchanged. So I just sent an email to iFixit EU. I’ll keep you posted.
par
Ajouter un commentaire
1 solution
Solution retenue
New batteries always come with a charge, this is to protect the battery itself from damaging itself. Of course voltage will drop over time. First things first, double check that all the connectors are firmly in place, they should give a small click sound. But don’t put too much pressure on them as you can damage them easily.
If all the connectors are connected properly, it could be possible that you received a bad battery (it happens). Simply contact iFixit with all the information you have, what you troubleshooted and they should replace it for you.
Cette réponse a-t-elle été utile ?
Indice 1
Commentaires:
Got a replacement and it worked like a charm. Many thanks for your advice.
par
Good news :D happy to hear your device got fixed!
par
Ajouter une réponse
AbeDaBabe sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 47
