Older LG tv loss sound
42 LH20D
suddenly lost sound. Pre digital so run through my computer . Also use sound bar
Have reset factory settings. Set output to pcm and tv speakers off. When toggle to tv speakers on can hear faint steady static from tv speakers. Sound level bar and mixer on tv shows no audio coming in
Thanks Ben
Update (02/20/2021)
Ok have worked out it is only when I go online (Netflix etc) that sound does not run through tv. Sound check and movies on my computer has sound but cuts off when I go online. I checked the driver update on computer anks was up to date.
Ta Ben
Hi,
Can you prove that audio is leaving the PC by connecting it to another device?
Or maybe prove audio in TV is working by connecting another device to the TV e.g. dvd player etc (you didn't specify connection type used between TV and PC?
Most older models also have Component video and Composite video
par jayeff
Hi thanks for reply. As above I have checked and it all runs with sound until I go online. Thanks Ben
par Bennyb
@Bennyb
If there is audio to the TV from the PC when viewing and listening to local content from the PC then the problem is in the PC not the TV if it only happens when online.
Have you tried a different browser in the PC?
If there is no audio at anytime, online or not, on the TV from the PC then how's the PC connected to the TV, HDMI or vga + audio?
If vga do you have audio out on the PC 's audio out jack (headphone jack?)
par jayeff
