white screen and digitizer not responding
my iphone 3gs had a prob of the power button it didnt work at all
so one day i decided to open it up and see whats wrong with i . i thought maybe its the plugs
so wat i do is open the thing tilt up with screen and unscrew two of those screws on the right bottom side .
and lift up the logic board and let it shut down .
den took it open and saw nothing was wrong so i assembled them back and all i get is a white screen and digitizer is not responding but everything else is working i tried holding down the home button and the voice command work`d
is it i hav to change it digitizer and LCD
but i tried giving a hard look at the pin they were str8
but after 15mins on standby i press the home button and the screen comes with white screen along side with discolored lines
Did you properly reconnect cables 1 and 2 at top end of iphone?
If cable 2 isnt connected and cable 1 is loose this will give that exact fault.
Maybe also try restoring as this sometimes works.
Hope I helped.
par Ash
seems like i need a lcd but i dont understand y the digitizer played up ! :(
par shirneet
Turn your phone off. Open it. Reposition cables as ash suggests. They can be tricky!Use a guide on the right to open phone safely.
par pollytintop
i cant turn off the fone cos power switch doesnt respond
par shirneet
it's up to you..having had a backlight issue after opening when powered on, I have learned my lesson...Sounds like the cable connections are the problem, they pop off really easily when you open the display
par pollytintop
Afficher 1 commentaire en plus
