Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Variante uniquement Wi-Fi de la cinquième génération d'iPad, lancée en mars 2017. Disponible avec 32 ou 128 Go de stockage en option, écran Retina de 9,7" et processeur A9 de 64 bits.
Questions au sujet de 78 Voir tout
iPad Home Button not working after Digitizer Replacement
I replaced the digitizer specifically because I accidentally broke the home button connector ribbon. I have to use the one I have (the new one I mean) or buy another. When I connect the digitizer and LCD panel, the home button does not work. I have not fully assembled the iPad yet, as I wanted to check if it worked. Do I have to fully assemble to get the button to work? and if not then can anyone see my problem?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 solution
Réponse la plus utile
That looks like an iPad Air home button, which carries a different protocol and is not compatible with iPad 5.
Either that or the home button is faulty.
Cette réponse a-t-elle été utile ?
Indice 1
Commentaires:
That’s actually a really helpful input, when I bought it it was labeled as a digitizer for iPad 5 or iPad Air. So does this mean that it just really isn’t the right home button?
par
@Nathan Mayo That explains it, you got the wrong home button (iPad Air)
par
Ajouter une réponse
Nathan Mayo sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 14
