Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
1 commentaire:
Chances are your charger is either dysfunctional or doesnt provide enough power to the tablet, try isolating whats going on. Try a different charger if it works you know the OG one is either broken or insufficient.
This is probably not an issue with the tablet itself, this is probably the charger you’re using. Try using the charger provided by the manufacturer or use a different cable/adapter.
par Reagan
