Hi @luigiboard
Try using the Windows troubleshooter and see if it can resolve the problem.
If Win10 go to Start > Settings > Network and Internet > Advanced Network Settings > Network troubleshooter and follow the prompts
@luigiboard
More things to try:
a). Try a Network reset:
1. In the search box on the taskbar, type cmd, then when the menu option appears select Run as administrator
2. At the command prompt in the Command window, run the following commands in the listed order, one at a time, and then check to see if that fixes your connection problem after they have all been entered and the PC has been restarted:
Type netsh winsock reset and press Enter.
Type netsh int ip reset and press Enter.
Type ipconfig /release and press Enter. (Yes there is a space inserted before the / symbol in the command string of this and the following commands)
Type ipconfig /renew and press Enter.
Type ipconfig /flushdns and press Enter.
3. Restart computer.
b). If still no good, can you connect to the internet by using an Ethernet cable connected to the router from the PC?
c). Try starting in safe mode with networking and check if that works OK.
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
2 commentaires
Hello, I have the exact same issue.
I have tried doing a full network restart, uninstalling and installing the newest wifi driver using USB, changing my wi-fi card. Nothing seems to work. Would be lovely if anyone can have a better solution.
par Sad Student
If your device is able to connect to Wifi signal A (i.e. hotspot in this example) and get internet, and can connect to signal B (i.e. home wifi) but not get internet:
If you've done those things, have you also tried safe mode with networking?
Hold down shift when restarting your computer. Continue holding shift until after the restart and a new screen will pop up with restart options. On most Windows, Safe Mode with Networking is option 5. Boot into that mode and try again.
If all that fails, perhaps there is some issue where your router does not like that particular connection. Try connecting to your router, typing in your local IP into a web browser (usually 192.168.0.1 on most USA models, may not be true worldwide) to connect to the router itself. Check your router settings to see what it is saying and why it doesn't like your computer.
par Justin Castle
